G'day all,
I'm looking at replacing all my bearings in second sets of hubs/swing arms. Ive got a second set of swing arms so no problems there; and i've got a set of front hubs from a 2wd.
Now, I can't see any difference in the 2wd hubs to the 4wd hubs. What I want to know for sure (as I already presume I can do this) is: Can I replace the 4wd front hubs with the 2wd front hubs and not have any problems in fitment?
L series hubs - just want confirmation 2wd/4wd the same?
I believe they should be identical. L series all have front driveshafts and the outer CV splines that go through the hubs are the same.
EZ30 L series - Monsterwagon
- FROG
Should be fine el freddo
only gives me one part number
- FROG
x9061ga000
gets you from subaru the two bearings and two seals as a kit for each side retail is around 100 bucks
just a thought fyi
just a thought fyi
