Gearbox sale! Take them away
Posted: Mon Sep 27, 2010 9:54 pm
I have 2 gearboxes sitting in the yard that need to go.
1 x standard RS turbo box, don't know much about it as it came in my vortex. Should be a 3.9 with the reduction rear extension to 3.54. Broken rear drive gear - behind the centre diff. Gears in the front casing should still be fine although bit tricky to get into reverse at times. $50
1 x L series dual range box, 3.7 ratio, out of Josh's L series touring wagon from the ej converison. approx 300k kms. Tourer was an mpfi, not sure if they had different ratios to the stanard carby part time box? Does anyone know? $50
no pics of the L box, you know what it looks like
post here or pm
cheers.
Sam
post here or pm
cheers.
Sam
