looking to get a L series need advice
- tas brumby
well tomorrow i am looking to get a l series wagon and am interested to find out  what i should be looking at as i have only every had ej motors    any advice will be appreciated
cheers justin
						cheers justin
the best advice I can give is to put an ej motor + awd box in it, even an ej18 is head and shoulders above an ea82.
In all seriousness, whip off the oil filler cap when its running and put your hand over the tube to feel for excess blowby, check the inside of the cap for coffee whilst your there.
Give the water pump pully a wiggle to see if theres any slop, rough guide to how shagged the bearing is. (worn bearing will quickly wear a seal.)
Buubles in the radiator are not cool, also look for salty residue (because we all use distilled water right?) around the overflow bottle for more possible evidence of shot head gaskets.
Turn the heater on when you test drive it, even if its stinking hot. A leaking core is not fun in winter and will make bargining easier.
Any more details? Tourer? Injected?
'97 Outback - almost back to grandma spec operating condition.
"A day is never more than what you make of it."
I will have a white one for sale in a month or so..
Great shape and 230,000 on the clock.
Factory apart from white sunraisers.
PM me if you would like some details.
1989 Subaru WonderBrumby II
- tas brumby
- tas brumby
