Upgrade Shocks
Upgrade Shocks
My shockies on the L series have never been changed so i was just seeing what is available and what is standard price for parts and fitting. I have king springs installed already. Does upgrading shocks make any difference to clearance or the lift of the car?
Everyone seems to get KYB shockies, how much are these and where are they best purchased from around Perth? I rang Pedders and they said they could only fit Comfort Gas shocks all round and the price ended up over $1000.
any info and suggestions would be great cheers
Paul
Paul
88 L series Sports Wagon, Weber 32/36 carby, 2" Lift Kit, King Springs all round, 14" Desert Rats, 27" Super Trippers, Welded Rear Diff, Dark tint, JVC Mp3 Deck.
						did you just install the rears for any particular reason, or u gunna do the front ones soon? $85 seems to be a good price and you reckon get the 2wd shocks for more height, are they stiffer then the 4wd ones? can u notice the difference in the rear with your car?
						Good place to get KYB's from is WA Suspensions in Osborne Park. They are the WA disty for them.
Have a go at self installing if your keen, its fairly straight forward.
so for the front i should get 4wd KYB shocks and for the rear get 2wd KYB shockies? thanks for advice fellas. Alot better than what Pedders offered me.
cheers
									cheers
						Get the Kings Springs to suit the L series, they are abit longer.
The Kings website has the local distributers listed I beleive.
The information below is from an email i got from King Springs, a very prompt response it was too.
Cheers Mark
Thankyou for your inquiry,
We have King Springs Part No's KFFS-45 (front) & KSRS-02 (rear) to maintain factory std height.
These coils are designed with an increase in spring rate of approximately 25%.
RRP is $ 160.00 + GST per pair front
RRP is $ 160.00 + GST per pair rear.
Please contact the following King Springs Distributors for a price & availability in your area:
Autobarn, AutoPro, Checkpoint, Fulcrum, Repco, Supercheap, Bursons & most leading suspension specialists
						Cheers Mark
Contacted Lovells, the return email says that have nothing available for the L series subaru.
My question now is-- if you have replaced coil springs and gained more height which make and model did you use?
In Tech Talk section - Lifting a Subaru of this website
King Springs (probably because one brand is actually named King), they are about 33% heavier duty than standard and provide both more tension and vehicle height
Every one i have spoken to so far are able to locate replacement springs that are listed as standard height. Some are also listed as heavy duty.
Do the heavy duty standard height springs also raise clearance?
Cheers Mark
Cheers Mark
Yeah they do raise height but mostly because they are brand new (your old ones will be sagging) and also because under compression they will compress less becuase they are heavy duty.
I have seen L series subarus with Lovells springs before, whoever dealt with your enquiry probably got confused with MY series Subarus. Either that or perhaps they no longer manufacture that model. Doesn't matter anyway, general opinion is Kings are better.
Note - they have quoted you on SEDAN springs for the rear.
The part number for Wagon ones is KSRS-03.
If you have Munroe rear shockies you will need to order the Kings springs designed to suit them. KSRS03M. I think the spring base is slightly different on them.
**edit - somebody should probably move this thread to the suspensions section.
