wrecking L series
tony
wrecking L series
Post by tony » Thu Jul 14, 2011 2:05 am
still got most parts from l series.
fuel tank $30 good condition
all doors good nick $20 each silvery blue colour
complete rear cutoff diff/axle drum to drum with struts $45
gearbox duel range $75
air con factory air still installed in front cut you get the whole front cut with reasonable dash pad struts brakes firewall etc no instrument cluster $120
putting it here because the classified still won't accept my ads.
front/rear seats not real flash but no tears or damge need clean $30 lot
will bring to perth if requested I can't stash em in perth due to space problems.
this stuff must all go make an offer
Post by steptoe » Thu Jul 14, 2011 9:19 am
RSR Paul is looking for Touring Wagon gate gas struts......
Dann
Post by Dann » Thu Jul 14, 2011 9:27 am
is it a touring wagon?? if so dibs on the fuel lines and tank :)
Dann
Looking for:
- LSD diff
tony
Post by tony » Fri Jul 15, 2011 1:54 am
is the touring wagon the one with high roof? if so mine is not a touring wagon it is a sportswagon.
would not have thought the fuel tank and lines would be different.
anyway the fuel lines are stuffed as I cut them off.
Post by AndrewT » Fri Jul 15, 2011 8:51 am
The fuel lines, pump and tank are only different if it's an EFI touring wagon (88 onwards I think). The earlier ones are still carby and have the same tanks as all the others - I had one of these cars, an 85 model.
Post by steptoe » Fri Jul 15, 2011 9:58 am
Touring Wagon is the high roof - yes. OK 'nuff said, thanks :)
ashleyn
Post by ashleyn » Fri Jul 15, 2011 10:55 am
tony wrote:still got most parts from l series.
I'll grab the front seats if that's OK. Where is the pickup from ?
Neil
Post by RSR 555 » Fri Jul 15, 2011 12:06 pm
Where are all the high roof (Touring wagons) models?? never around when you need one :???:
tony
Post by tony » Fri Jul 15, 2011 2:09 pm
Ashlyn I will bring the lot to perth next week if you choose to dump the rear seat your choice or I can dump them here.
will be coming from around jurien so if you are north of river can drop the seats in.
Also found a towbar $25 and a set of roof bars with reinforced bar $80 also nudge bar ally, appears to be roo bar cut down, has bottom bar bent, still looks good, would straighten easy, still mounted to bumper, bumper has some bending due to rope catching, probably repairable, $80 lot.
Complete lp gas setup, tank good to mid 2014, with mounts etc (goes behind rear seat) $75 lot.
all must go! make an offer!
Post by El_Freddo » Sat Jul 16, 2011 2:08 pm
RSR 555 wrote:Where are all the high roof (Touring wagons) models?? never around when you need one :???:
Over here :twisted:
Return to “Western Australia”
