CV's
- Richie-Rich
CV's
Hi Guys,
looking for a recommended CV place in Perth.
Front left and right rear are needing new boots and grease etc.
Rich
Rich
- TOONGA
Everybody keeps mentioning Allans CV's in Osbourne Park. (I think thats the one)
The store has been there for ever so he must be doing it right.
http://www.yellowpages.com.au/wa/osborn ... rredBy=YOL
- Richie-Rich
Couldn't you get a new shaft for less than that?? I got two front shafts for $175 each including GSTWagonman wrote:Last time I did my L series front CVs I went to Outer Control. It was easy for me because they deliver to my work. I recall I got exhange full shafts for $250 about 1 year ago
Does this include removal and fitment? Which rear boot? If its an outer they'd probably do both as you need to remove the inner boot to do the outer one - if you're using the proper boots and not the generic "stretch over everything and clamp in" type.Richie-Rich wrote:I heard that, i got quoted $190 for a rear boot replacement - seems high.
- Richie-Rich
i once had an inner front replace for like $40. Including the boot (when i cbf doing it myself)
190 is a jip off. which is weird, allens are usually cheap and do a good job!
