FS Ej22 motor
FS Ej22 motor
Posting for a mate , who has done a turbo conversion
Ej22 motor aprox 200,000 ks
c/w all the wiring ,ecu ,afm ect
$550.00
I also have another Ej22 long block ( cond is not known by me as I have not seen it run )
you risk it for
$40.00
$550.00
you risk it for
$40.00
Hi mate I can not see any oil leaks, I removed the fly wheel & its all good there as well.sorry I can not help you with a d/r gear box at this point of time.
O , all I know the motor was a driver , There is no water in the oil.
I may be able to get my bell housing back to do a compression test
cheers
cheers
EJ22ute - Alex (Keffa) has a 5spd dual range gearbox forsale. A 3.7 ratio I beleive.
- red_rocket
gearbox
I am after a awd d/r 5 speed box . Only problem is, i send heaps of messages to keffa and never get a reply. Last time i tried to contact keffa was about a clutch pack lsd diff.AndrewT wrote:EJ22ute - Alex (Keffa) has a 5spd dual range gearbox forsale. A 3.7 ratio I beleive.
rtcb65
Redneck Rick.
Redneck Rick.
thats caus keffa doesnt come on here anymore. its not an awd box, its a standard L series part time box
dave
									dave
Actually I'll be selling an AWD one myself soon. It's a 1999 Outback gearbox, 5spd dual range with hydraulic operated push clutch. Comes with fork, slave cylinder, master cylinder, clutch, pressure plate and flywheel. Pressure plate was custom beefed up to 2200pounds and the clutch still works well - held the power of an EJ20turbo perfectly fine.
It's got probably about 280,000kms on the gearbox at an estimate, still works good. PM me if interested.
