Auto Electrician
- Richie-Rich
Auto Electrician
Hi,
My indicators have decided to no longer work.
Chasing an recommended shop, or the name of the Aus Subie member who does home calls.
Rich
Rich
Sorry mate... i would be able to help you but i am up to my ears with people wanting Subi work done before christmas and i have had to tell them all i can't help till next year. Even my Monday to Friday work is not excepting any more work this year.
Dave
Dave
So let's go the remote diagnostic route......
what model??
My 84 Brumby suddenly had no indicators at all no glow, no blink - water got into blink unit from leaky windscreen and zzzt - new one fixed it.
If you have a towbar with a plug, check it, check your fuses, check each bulb works by remove and test on battery and come back......
what model??
Hey Rich, just give me a call when you're free and we'll try and work it out.
- Richie-Rich
Thanks Paul.
Expect a call on Tuesday, I have plans I wish to discuss.
Also boys, 97 Forester. About a week ago the indicator stopped indicating and just displayed a solid light, no flashing. Then suddenly id stopped working all together. The globes are fine as the immobiliser still makes the lights flash, I'm guessing i have a loose wire in the stalk.
Rej
Rej
I'll be around.. maybe even at the shopRichie-Rich wrote:Thanks Paul.
Rej
I'm thinking Immobilizer off hand.. have you got an aftermarket one fitted?
- sven '2'
Oh well.SuBaRiNo wrote:Sorry mate... i would be able to help you but i am up to my ears with people wanting Subi work done before christmas and i have had to tell them all i can't help till next year. Even my Monday to Friday work is not excepting any more work this year.
Dave
Good for Dave (good position to be in!), bad for RR - sounds like you'll be well sorted presently.
Cheers for the heads up Davo.. I'll check that out tomoz.SuBaRiNo wrote:Unlikely to be imobiliser. Sounds like a flasher relay fault to me. Try the hazard lights and see if the indicators flash with them. I forget if the indicator flasher relay is the same as the hazard flasher relay on that model.
Dave
God hope not.. I have enough sh*t to do myself. Dave can keep the electrical stuff !!
