first how do l get it of the steering column to replace ?
next how has one (for a91 brumby) they don't wont need ?
l got the two screw's out  one top one bottom , then there is two more screws that don't have slots for a screwdriver .
						ignition switch
- littlewhiteute
PM replied Laurance
If the key turns, then just turn it to the acc position and push a your screwdriver on the little button below the barrel, then pull the whole barrel out and replace with new one. If the barrel is worn, then you'll need to remove from the column.
I also forgot to mention that if you find a 2nd hand one.. ask to keep the philiphead screws and just put all 4 in place. The standard Brumby's aren't high on the thieves most wanted list. clearly they don't know about them
