WTB l series fuel in line
- Mr Top Hat
hey Guys
does anyone have a carby L fuel in line or mpfi return line in their shed somewhere?
A-part wreckers says they dont really do L series stuff anymore.
and it holding up my conversion because i need a bigger return line for the EJ22
and would the standard carby fuel in line be ok for the EJ22 fuel in line right?
thanks
Rob
thanks
Rob
1990 L series wagon Ej22
i didn't realize this image was so large :-O
from memory i just beafed up the fuel lines to EFI lines and used all proper worm drive hose clamps. The standard clamps and hoses arent beafy enough.
Yeah Rob I'm running a standard carbie fuel-in line for both the in and out lines. No issues from a fuel pressure point of view.Mr Top Hat wrote: and would the standard carby fuel in line be ok for the EJ22 fuel in line right?
The extra fuel in line can be a pain in the arse to get in, I didn't cut mine down as I wanted to retain the crushed out buldge to help seal the line, so its got a massive "S" shape under the bonnet. I simply cable tied with some foam to the other fuel lines to mount it. Then did the rest as Alex said - beefed up the rubber lines and clamps to EFI rated stuff
- Mr Top Hat
A surge tank is a good idea (getting halfway up a steep hill and having the engine starve and stall can be scary), but your metal carby fuel lines will be fine. Replace existing rubber lines with EFI-rated hose.Mr Top Hat wrote:oh really so all the excess fuel can happily go through the carby fuel return line, no surging?
Dane.
Sorry, you've miss read my last post. I'm using a fuel IN line for the return line as well - sourced from a carbie fed L series, just reshaped the end in the engine bay.Mr Top Hat wrote:oh really so all the excess fuel can happily go through the carby fuel return line, no surging?
With a standard carbie return fuel line my MPFI I had a few years ago would surge under acceleration but didn't do it all the time. Had me stumped as it did it with two different engines... So I swapped the return line when the EJ went in - no issues with fuel so far, just cam belts and bearings after drowning the interior...
Worth the effort I reckon for piece of mind if you can source the stock carbie fuel IN line
I think i kept a few bigger fuel lines when i moved. I can check when i get back and let you know if you want bigger lines.
- Mr Top Hat
Have you not "upsized" your fuel return line Dane? Had any issues with over pressurising of the fuel due to the return line being a restriction?GOD wrote:A surge tank is a good idea (getting halfway up a steep hill and having the engine starve and stall can be scary), but your metal carby fuel lines will be fine. Replace existing rubber lines with EFI-rated hose.
El_Freddo wrote:I also changed the fuel return line for another L series fuel to engine line –]http://img514.imageshack.us/img514/2163/p8081609.jpg[/IMG]
Quoted from here
There's a comparison to the stock carbie return line and fuel in line, hence why I swapped to a fuel in line for the return
Painful job though, interior has to come out down the left hand side of the subi, you should have enough room under the dash to get it in, I just managed to do mine with the dash in!
i never touched my return line.
i did have overpressurising problems, but only on hot days, she did surge abit.
if you disassemble your fuel cap, drill a hole in the little metal bit and replace it youll be fine
worked for me.
worked for me.
