Looking for a Subi tuner...
put the ej22 in my L series. it goes like a shower of shit but eats the fuel like its nothing.
is there anyone in perth that knows anything about tuning it up so shes a bit more economical? or even better, someone who will dyno it aswell?
1989 L Series Wagon
3" lift, 27/8.5/R14 Muddies
EJ22
EJ22
it is sort of the O2 sensor that keeps things in tune fuel wise. you got it working and no fault codes? kept the L series box and diff ratios too? Been thinking these EJ conversions that change box and diff ratios and standard tyres may have a bearing on fuel consumption if not matched. Of this and EJ's I no nothing, but worth a thought. What if you drive a little tamer for a tankful and see if economy improves?
its married to standard box. running 27" muddies. no warning lights. i'll look into getting a new O2 sensor and see what happens. would having a 2.5" from the extractors back cause such a significant problem?
drivind tame isnt the issue. i dont balls out much in it on the streets.
1989 L Series Wagon
EJ22
EJ22
Hi Kieren,
Sounds like you have done the swap.....gutted my poor old L !.
Interesting that you are using lots of fuel, it didn't appear to when it was in my L (350-400K to the tank), however I was comparing it to the heap of fuel it drank with the Weber + EA82 + heavy foot (250K to the tank) with the EA82 it used more than our old V6 Commodore.
Are you going to post some photos.
rob
rob
How many kms to a tank are you doing?Kieren wrote:put the ej22 in my L series. it goes like a shower of shit but eats the fuel like its nothing.
That is not particularly good economy. I get 500+ in mine with the Ej20turbo motor. Probably alot to do with driving style I guess, also tyre size.robdddd wrote: Interesting that you are using lots of fuel, it didn't appear to when it was in my L (350-400K to the tank),
The ecu can't really be "tuned" - it's locked to factory settings and adjusts according to what information it receives from the various sensors, but if one or more sensors are faulty then it all goes to sh_t. Definitely check O2 sensor or get it connected up to a fault finding system as suggested.
EZ30 L series - Monsterwagon
Tune Rx with 2.0Rs
Hi anyone know where i can get a good base tune for a Rx with 2.0 turbo Rs Engine and WRX VLSD G/Box & Diff. Engine management is Wolf 3d V4. I thaught i would put it on a 2Wd Dyno but of course as soon as i took out the rear half shaft she didnt move.Is Road tuning the answer?
Thanks.
Mick
Thanks.
Mick
- d_generate
Can't you read MORON, he's in Victoria, don't think anyone in Perth touches Wolf's
Hahaha.. be nice Tomd_generate wrote:Can't you read MORON, he's in Victoria, don't think anyone in Perth touches Wolf's
There was a guy that used to own SST in Welshpool that used to tune/dyno the Wolfs.. he did my 1UZ in my Surf. I'm 99% sure he now works at one of the places that sell high preformance gear for fords/holdens.. you see it on Leach Hwy between Abernathy and Orrong.
But for Vic.. I'm sure there would be heaps of guys. Mick G check out the wolf website, Im sure there will even be some with AWD dynos.
