Where are all the Victorians?
Just thought i'd open another topic up to level with the number of topics NSW has (2)...
So, where is every one? (most likely in Queensland, that seems to be where most victorians are... i'm going to check their posts now...)
El Freddo
El Freddo
- hughybabes
johno
- hughybabes
- hughybabes
Guest
- hughybabes
Yes, Ive been on the Olinda Basin road often. I live in Upwey. We'll be keeping an eye out for each other now, I reckon.. I heard a very nice sounding white Brumby sitting at the lights in Tecoma. Does yours have a nice exhaust note?
1984 sportswagon
ea81 twin carburettor motor.
"d-shaped" siamese exhaust port heads.
mild low torque cam. electronic dizzy.
2.5 inch engine pipes; 2.25 tail pipe; rear sports muffler.
Guest
Yeah, it does have a nice sounding exhaust. Not real loud though.
It's not lifted anymore. Measuring from the rear stub axle to the rear wheel arch it is 100mm lower than my mates stocker.
Yes you probably would have seen it in Doncaster as I use it for work and average 100km/day anywhere between the mountain, Brighton the city and Ivanhoe areas.
It has the brake kit I'm developing and early wrx 15's at the moment but I have a set of Lib rx 2.5 wheels I'd like to put on it when I can afford new 205/50/16 tyres.
I think all us Vic board members should organise some get together BBQ's etc. I can't go offroad though as my car is set up to corner and is too low for anything bigger than a speed bump.
How many Vic. members are there?
Guest
xaymaca does your Brumby have a big hole under the battery tray? and have the auto tranny cross member mounts been removed from the body underneath?
I had an 87 that I had converted to Targa and 4 headlight front.
Hi to Jono. I don't know if you remember me but I think I sold you some bits and pieces a while back at your place.
Hi to gtlegs. I don't know if you remember but I think I met you at centre road wreckers once.
