Hi All
I'm chasing a couple of secondhand working remotes for a 2000 Forester at a reasonable price.
Can anybody suggest where I should go or contact I 'am in Perth WA
Thanks
Westernbill
Forester remotes
- Bantum
Re: Forester remotes
Would try Subarino - he should know someone ...
Cheers, Bantum ...
Cheers, Bantum ...
Thanks for that will try
Westernbill
Westernbill
You’re probably better off getting a set of new aftermarket fobs and have them programmed to your vehicle. A second hand set would need to be programmed too.
Your local locksmith should be able to do this work for you
- Bantum
Re: Forester Remotes ...
For those following, I recently got hold of cheap reproduction fob from China - Will see how it goes.
Visit here for range of remotes : https://www.aliexpress.com/store/149106 ... match_sort
You'll still need to get it cut & programmed from local locksmith.
Cheers, Bantum ...
Cheers, Bantum ...
