Forester remotes
Tips & Tricks to getting in or out of your ride ...
symo42
Forester remotes
Post by symo42 » Thu Oct 20, 2022 3:21 pm
Hi All
I'm chasing a couple of secondhand working remotes for a 2000 Forester at a reasonable price.
Can anybody suggest where I should go or contact I 'am in Perth WA
Thanks
Westernbill
Re: Forester remotes
Post by Bantum » Fri Oct 21, 2022 5:10 am
Would try Subarino - he should know someone ... :)
Cheers, Bantum ...
symo42
Post by symo42 » Mon Oct 24, 2022 4:12 pm
Thanks for that will try
Westernbill
Post by El_Freddo » Mon Oct 24, 2022 10:04 pm
You’re probably better off getting a set of new aftermarket fobs and have them programmed to your vehicle. A second hand set would need to be programmed too.
Your local locksmith should be able to do this work for you ;)
Re: Forester Remotes ...
Post by Bantum » Wed Aug 28, 2024 2:07 am
For those following, I recently got hold of cheap reproduction fob from China - Will see how it goes.
Visit here for range of remotes : https://www.aliexpress.com/store/149106 ... match_sort
You'll still need to get it cut & programmed from local locksmith.
Cheers, Bantum ...
Return to “Security - Locks & Alarms”
