Wheel Aligment
- caboolture
Wheel Aligment
Hello I'm looking for a workshop who understands how to do wheel alignment on lifted Subarus in North Brisbane/Caboolture areas.
Cheers Peter
Cheers Peter
1991 gx 3" lift 16" gt Forester alloys,215/65/16 outback struts and pedders raised springs, Turbo motor,gearbox,diff,brakes,bonnet etc now transplanted
Did you have problems with your local wheel place? or they don't understand about lifted Subarus? (I have the same problem here as well)
- caboolture
Both the workshops i've taken it to have new equipment and they compare the print out with a standard 91 liberty specs and want to oblong the holes in the struts. I'll try goodyear. I've seen another lifted Subaru there. Thanks Peter
really whats not to understand?
if youve got suspension lift your going to throw your camber out, them wanting to oblong the holes in your struts must mean you have Positive Camber and they are trying to correct it for you.
Toe alignment i cant see being a problem for them to do.
Caster - there isnt any that i cna remember on the libbos unless using aftermarket strut tops
Wagon is no longer....
