EA81 supercharger revamp by Tweety
For those that have a 2 wheel affliction, share away here !
Tweety
Post by Tweety » Fri Nov 29, 2013 8:38 pm
ok. no ECU needed.
4 terminals ABCD
Resistance between Band D should be 4700 ohms
Between B and C resistance should be under 1000 ohms closed throttle
B and C should be OVER 2400, throttle open full (or more accurately about 80% of B and D)
B and C should change continuously through the rev range. If not its f...ked
Make sure B has 5 volts.
cheers
Post by Gannon » Fri Nov 29, 2013 9:02 pm
Got a photo of the TPS
I wouldnt be surprised if the TPS from a vortex hi-rise manifold or even an liberty would fit
Tweety
Post by Tweety » Sat Nov 30, 2013 9:42 am
had a "D" hole for the throttle shaft. 4 pins. were on all SPFI loyale's 1985-1994 all the same
Post by Gannon » Sat Nov 30, 2013 10:11 am
This is a diagram of an EJ22 MPFI engine TPS
Post by Gannon » Sat Nov 30, 2013 11:39 am
This is the TSP off a vortex EA82T
Post by steptoe » Sat Nov 30, 2013 1:17 pm
Tweety wrote:ok. no ECU needed.
4 terminals ABCD
cheers
The terminals on mine are not marked ABCD, but gathering that the tit on top is how the plug is to be viewed ?
Post by steptoe » Sat Nov 30, 2013 1:26 pm
with tit to top
B D is 4.72 closed throttle, 20k scale
B C is .540 on the 2k scale closed throttle, set to 200 Ohms scale says 1, so must be 540 ?
BC starts at .540 and climbs slowly up to 3.970 in the 20k scale as I open throttle gently, comes along nicely, progressively...so guess it not flicked
DARN no 5V at B !! No ECU ?? ;)
Post by steptoe » Sat Nov 30, 2013 1:31 pm
Tony, have I asked you wjhich of the three ports you hooked up vac advance to ??
Tweety
Post by Tweety » Sat Nov 30, 2013 1:47 pm
3 vacuum ports? no idea what you are talking about Jonno. (remember I'm no mechanic lol)
I think A goes no where.
These TPS's seem the same as mine- damn. but I've seen things that look the same and arent. the later MAF of the ea82 in US has a different larger housing. same part number just a 3 in small raised lettering hidden somewhere compared to a 2.
Subydoug
Post by Subydoug » Sat Nov 30, 2013 4:36 pm
Had a quick look at the one on my 85 N/A MPFI ea82. Is only a 3 pin job, so anything pre 87 on the MPFI engines probably wont work.
Doug
Post by steptoe » Sat Nov 30, 2013 6:04 pm
The early ones on mpfi EA82 turbos anyway were three pin TPS and were just switch postions such as throttle closed and throttle almost fullu ully open. Thought the four plug ECU TPS were different ? Also got a three pin TPS with three wire plug coming out of it for additinal hook up to who knows what ?
With the rising rate of ohms as throttle opens this is more like how a four plug ecu TPS is thought to work. The simple throttle position switch of earlier type works OK !
Tweety
Post by Tweety » Sun Dec 01, 2013 4:12 pm
yeh your readings are correct.
I recall that guy at Peddera Shepparton telling me the MAF was likely faulty and it was, read low on the volts from memory. He said the throttle should respond quicker and it was likely the culprit for low power output.
I'm starting to think my TPS was also faulty, so two faults equaled issues. Remember I have a bad flat spot at 3 quarter throttle. My hope is that one of these TPS's I'm getting from Canada will result in fixing all issues.
Post by steptoe » Sun Dec 01, 2013 7:56 pm
Well, mine work tit up. Looking at the EJ tps it would likely read in order with tit down on tps ? Tony, if you do the closed to open range on your multi meter, do you get a smooth increase in the Ohms as you opn 'er up just as smooth, or do you get a bump in the Ohm reading to match your flat spot ?
Can you pinpoint anyone in perticuler that started you off on this spfi tangent ? The progress has made it one of the more memorable projects taken on in here.
Projects gone a bit quiet in here, hey?
Tweety
Post by Tweety » Mon Dec 02, 2013 10:06 am
Jonno, I'll check the TPS soon for that flat spot- good idea. I've had it apart then quickly put it together again as it was out of my depth.
Tweety trike has certainly been through some loops in its 5 years. Started out with a new 1916cc VW engine made in Brazil then shiped from California in bits to Woolongong where it was assembled then to Gosford for installation in the trike. My mate and I collected the trike on 8/1/2009 to trailer it down to Euroa.
50 kms after that the engine died. Some thought it was the dizzy so another one was sent down. Eventually the Woolongong boys returend to collect the engine. A week later they returned it with a new set of german cam gears, the others had stripped.
The engine never did run right. Eventually it was stripped down to reveal a score in one bore 1mm deepx3mm wide the complete length of the bore and 7 bent valves. This was all done on warranty and I swapped the Solex's for webers. Eventaully I made the decision to go Subaru.
Yes, I should have gone EJ20 or 22. I was worried the VW auto wouldnt cope with the power and I falsely believed those engines would need engine mounts. The Panther is a monocoque alloy chassis. Engine mounts are not possible without major engineering.
The ea81 was chosen for reasons that it had the lowest revs for the torque output compared to other Jap engines of similar size. No good putting a high revving Honda engine in with that auto. I wanted a cruising engine that had to be easy to work on.
After a weber was put on the ea81 I wasnt happy when I towed our van. The slightest rise in the road saw it kickdown. Hence the move to a supercharger.
I loved the power of the SC. But it wasnt as economical as I needed. And with a possible retirement looming I knew we could not afford to keep it that way. Then Dean of Mt Evelyn suggested I buy his SPFI. It was the answer for me and still is. The stock Ea81 at 74 hp, the SC12 at over 100hp and the SPFI at 90hp. I'd be happy with that.
Since installation we discovered cracks in the Panther frame that caused fuel leakage. It meant the swing arms needed to come out. A cool $4000 bill. So the van has gone up for sale. Its just too heavy to tow with this machine. We plan to buy a alloy trailers and convert it to a camper to keep under the 250 kgm limit gross.
The SPFI installation was a challenge. I didnt know what all the sensors were for - anything about it really. This forum and USMB were critical to my learning. I like the ease of starting, that it thinks for itself how to run correctly. etc. But I believe the MAF and TPS were both defective. I will know shortly upon the installation of another TPS next week or so. Then Tambox's friend with his dyno and minor adjustments might see its full potential. I'm getting 28mpg (10.2 L/100km) now so am happy. That might get better.
Big regret not going EJ in the first place. To do that now is out of the question, adapter plate, exhaust and now forced retirement all combine to keeping the ea. On the other hand it does what I want it to do, smooth running easy starting and simple to work on. The EJ would be a little over my head IMO. And the engine bay might be restricted.
SPFI on an EA81 is a good installation. The guide by Kelly Huff was easy to understand. The wiring (assisted by El Freddo) was straight forward. It the sorting of the gremlins that cause the pulse rate to rise. In the end it will be a distant memory.
The only thing not similar to the EA82 SPFI will be the compression ratio. 8.7:1 when it should be 9.5:1. Couple of years time a recoed engine or shaved heads to achieve this will happen.
Tweety
Post by Tweety » Thu Dec 12, 2013 9:15 am
BEWARE! ordering parts from USA. An interesting read here. My thread on USMB.
http://www.ultimatesubaru.org/forum/top ... one-small/
Tweety
Post by Tweety » Thu Dec 12, 2013 11:32 am
this is the latest reply from Rockauto and an extension of my post on USMB.
Well again a quick reply considering we are on the other side of the globe.
Here is a response from Rockauto. I mentioned I have outlined my ordeal on USMB.
"Thanks for your response. I've reviewed that
forum and we still not accept your return. RockAuto offers a 30-day return
window for all parts, as long as they have not been installed and are in the
original packaging. Since your order is more than two months outside
of the return window, we will not be able to accept your return.
We do value your business and thank you for shopping with RockAuto!
Thank you, Will
RockAuto Customer Service"
So, thanks to Rockauto guys, I have a MAF for sale. Same part number as an original Subaru EA82 SPFI MAF but doesnt fit my SPFI system of 1989 vintage as advertised by them on their own web site. And to top it off I dont know what this MAF comes off, what it fits.
Perhaps I can be clever- I can advertise the part to fit an EA82 as it has the same part number and sell it for the same huge amount I paid for it to a guy in North America. I'll have a 30 day money return guarantee but by the time it hits your shores, you open it up (so its no longer in the original packaging as required) and discuss the issue time will be up.
Nah...could never do it.....I could never be such an arsehole.... end post to USMB
So Ausubaru guys. I have a MAF for sale. anyone know what its off?
Post by steptoe » Thu Dec 12, 2013 3:40 pm
OK - you've got it now ! Any harm in actually trying it to see if it runs right with it, other than it does not fit directly BUT it might work and go just like a new one !
Post by Gannon » Thu Dec 12, 2013 4:52 pm
I cant see why it wouldnt work, even if it is a nissan item. I believe that the larger 90mm AFM of the STI and B4 Liberty can be interchanged with a certain Nissan AFM
Tweety
Post by Tweety » Thu Dec 12, 2013 8:38 pm
I agree, its worth trying. But I found another from a wrecker and they sent it here less than $50 including freight ex USA.
And that one works better than the original one. will bring the large one along with me when I meet up with Tambox soon. we can see if it is achievable to fit it. i has a much larger gullet.
wouldnt be hard to fit.
fun and games.
Tweety
Post by Tweety » Sat Dec 14, 2013 2:47 pm
swapped the perfectly good working MAF with the larger one from Rockarse auto. Started ok but ran crappy and idled poorly. back to the good one. will move on from the Rockauot experience. wont be using them again.
Return to “Bike Projects”
