How we made it to attach? I made 15mm thick hardened steel block size of 250mm long by 120mm wide with an V shape hook (its approx 12mm thick hard steel) with weld on both sides (top and bottom) before I welded it up I drilled a small V hole to fill up with weld, I used MIG weld (with gas) for that task attached on the H Beam with 260mm bolts with a block same size as above. I've already bought 2 ton 2.5m lift Block and Tackle (or Chain Block)
The H Beam shown in photo below is mounted on brick walls on both sides so I can tell its safe.
Photo of the Bracket (Centre of the bracket - used Arc weld on both sides just to join both into one piece)
To work out - what is exact weight I could lift?
Thanks & Cheers
