converting auto FWD to Manual FWD
Posted: Fri Mar 28, 2008 2:03 pm
by GTlegs
has anyone done it? How easy is it and whats involved for an L-series please?
Posted: Fri Mar 28, 2008 2:05 pm
by Suby Roo
Just a FWD gearBox i am assuming.
But i guess it depends on whot motor you have too, Carby of Fuel injected, If its fuel injected then you will need a manual computer as well.
But i dont really know, just guessing.
Posted: Fri Mar 28, 2008 7:48 pm
by GTlegs
Its a carb engine. I just want a manual gearbox in it.
Posted: Fri Mar 28, 2008 8:14 pm
by Ben
You'll need a gearbox, clutch and flywheel makes sure you get the flywheel bolts as they are longer than the autos TC plate bolts. You'll also need a pedal box with cables. Possible that you'll need to enlarge the trans tunnel hole (the one the levers come through) - I know you have to with an MY model. You'll also need the centre console pieces to suit. You may also need to mess around with mounts for the lever set.
