Thalass wrote:Man... Switchable locking diffs would be great. Though it ads complexity - and despite being a rabid geek, when it comes to cars I think they should be as simple (and therefore reliable) as possible. Also having a switch for that sort of thing is cheating! Like on that damn mitsubishi outlander.
I considered an Outlander before I bought my Outback,  As I remember it even though the switch is marked "4 Wheel Drive Lock" it doesn't really do that.  From what I remember on the Outlander forums it still allowed the power distribution from front to back to vary.
Edit:  Here it is:
"For driving in particularly challenging conditions, such as snow, the driver can select "4WD Lock" mode. In Lock mode, the system still apportions front and rear torque automatically, but enables greater power transfer to the rear wheels. For example, when accelerating on an upgrade, the coupling will transfer more torque to the rear wheels immediately, helping to ensure that all four wheels get traction. In contrast, an automatic on-demand part-time system would allow front wheel slippage before transferring power, which could hamper acceleration.
In dry conditions, 4WD Lock mode places priority on performance. More torque is directed to the rear wheels than in 4WD Auto mode to provide greater power off the line, better control when accelerating on snowy or loose surfaces, and enhanced stability at high speeds. Rear wheel torque transfer is increased by 50 percent over the amounts in 4WD Auto mode - meaning up to 60 percent of available torque is sent to the rear wheels under full-throttle acceleration on dry pavement. When in 4WD Lock mode, torque at the rear wheels is reduced by a smaller degree through corners than with 4WD Auto mode."
Reading about the Subaru VDC I think it is probably better than the Outlander system.
Rob
