Page 1 of 3
Various models of RX Turbo sedans
Posted: Thu Feb 21, 2008 9:24 am
by AndrewT
Just wondering if anybody has some concise info about the different variations of Rx Turbo sedans, differences in year models etc.
Mine is a 1986 Aussie model. It had 5spd dual range, NO power steering, NO aircon.
Strange because Discopotato's one is also 1986 but has p/s and a/c.
I suppose these could have been factory options at the time?
Posted: Thu Feb 21, 2008 9:35 am
by BlackMale
I am not sure if there is an “exact” answer to this 1, as you will also have to be aware of the import models as well.
Posted: Thu Feb 21, 2008 9:46 am
by RSR 555
I have 2 RX Turbos, both are without Pwr/Str. My 1985 model has A/C but my 1986 model does not, I'm guessing that as per normal cars sold in Australia at around this time, A/C was an option.
by Subafury
As you may be aware, Subaru imported the Leone-based RX 4WD turbo sedan to Australiain the mid/late ’80s. But we never received the gun model. In Japan, buyers had access to the full-time 4WD Leone RX/II coupe!
While the 5 speed manual version of the Australian-spec RX sedan had only on-demand 4WD with high/low range gearing, the 5 speed RX/II boasts full-time 4WD with a switchable centre diff lock and high/low range gearing!
info from
autospeed.com/A_2463/article.html
Posted: Thu Feb 21, 2008 9:49 am
by timmo
I think Subaru just made it as they went, whatever they felt like at the time. Theres also the auto trans models just badged 4WD turbo, not Rx. Lturbo, Steptoe & Me have these. Mine had "electro- pneumatic height adjustable suspension" go figure....!
Posted: Thu Feb 21, 2008 10:15 am
by AndrewT
Yer I figured the waters would be pretty muddied on this one!
Oh well mines got power steering now anyways. Aircon will be abit more work but I'll definitely do that too!
Posted: Thu Feb 21, 2008 11:16 am
by BlackMale
Yes Subaru Aust did import the RX themselves however private buyers could also import at that time. My first RX was 1 of these private imports... sorry if i was not clear on that.
My current RX (another 4 door import) has these options and is what my build project will look like (only in black. And i also have the center AWD RX display/lights to match - end hijack).
I thought years and years ago i heard that the RX was 1 of the first turbo car's Subaru build for rally. Due to the rally laws/rules at the time the car's had to basically be production cars on the factory sales floor and therefore p/s and a/c initially were not options due to needless increase in weight. May explain why they were not initially available with all the additional extras.
Posted: Thu Feb 21, 2008 11:17 am
by ToyRX
All the Jap spec ones I have owned in NZ have P/S and 2 of three had A/C.
They were all 85/86 models
Posted: Thu Feb 21, 2008 4:09 pm
by DavesB4
My 1986 Sales Brochures tell me that Power steering was not available on the RX Turbo but was on standard on Turbo AT models. It was also not available on DL either. My RX Turbo has had power Steering fitted later from an AT model.
Air Conditioning was not listed in the sales brochure at all but is included as a "New Generation approved Accessory" across the range which included Vortex, Brumby and Sherpa.
Posted: Thu Feb 21, 2008 5:00 pm
by Turbone
Wow, and we here in the States complain how you guys in Oz got all the good gear boxes(Libs with D/R) :p
The RXII from 87 to 89 in the US had the Full Time 5spd D/R with diff lock.
The 4dr RX from 85 to 86 had the 5spd D/R and no diff lock.
As far as I know, all Subaru's from 85 and on had P/S. But not all had A/C.
My RXII has P/S but no A/C. It has all the interior bits, just no compressor or condensor. Which is fine with me, no extra weight. But is a bugger in Summer because its BLACK.
The XT6 here has a Full Time 5spd with diff lock. Also comes with a Full Time 4EAT.
Posted: Thu Feb 21, 2008 5:48 pm
by sublime
Magazines such as Wheels, Turbo (anyone remember that one?) and Modern Motor all complained about the manual version of the RX not having power steering as standard (unlike the automatic) when it was first released (1986).
Most also complained about how bad the manual steering was as it was too heavy and had problems with torque steer. The power steering models were, conversely, highly praised at the time.
Posted: Thu Feb 21, 2008 6:08 pm
by discopotato03
I would expect that power steer and air con were factory options and would have been at a price premium .
As far as rally is concerned power steering is a big advantage when giving a FWD or 4WD car a bit of stick .
It was pure fluke that my 85 built and 86 first regestered RX Turbo had most of the Aus spec options .
My preference was to flick the AC because of engine cooling issues and the weight of the compressor and cradle are significant , a big plus is losing the hard to work around AC belts niggly tensioner too . The original single belt form easily drives the water pump/alternator/power steer pump . Actually my car has a longer than std belt and non AC alt mount brackets and this allowed
me to "hinge" the alt up higher out of the main rad fans air discharge path .
Because I like cars with lots of positive caster I would have fitted power steer if it was not std on this car , the extra caster makes manual steering heavy . Also generally power steer racks are beefier than manual ones .
As I said recently if I was ever to buy another one I'd really prefer the later 4 plug ECU cars which I think are mid 87 on .
When I get access to an 86 factory WS manual (next week) I must check up on the curb weight of 85/86 build cars compared to the mid 87 and on ones .
Cheers A .
Posted: Thu Feb 21, 2008 6:19 pm
by Subafury
discopotato03 wrote: As I said recently if I was ever to buy another one I'd really prefer the later 4 plug ECU cars which I think are mid 87 on .
why is a 4 plug better than a 3 plug? i have no idea what the difference is
Posted: Thu Feb 21, 2008 10:21 pm
by mattl200
4 plug vs 3 plug
showthread.php?t=3784
Posted: Thu Feb 21, 2008 11:00 pm
Dept of Motor Transport Vehicle Specificatins sheet number Subaru 18 on the 1.8l 4WD turbo sedan issued '86 april
tare weight of RX Turbo 1.8 4WD is 1070kg
tare weight of 4GLTA turbo 4WD is 1090
plus all the options of
air cond add 30 kilos ....option for both
tow bar add 14 kilos ...ditto
power steer std on auto N/A on manual
sun roof, who has one only on auto ..add 15 kilos
then , get this , lists sunraysia type white alloy wheels take off ten kilos for either and alloy wheels only available on the auto ? they are wrong are they not? take off 20kg for the alloys and take off ten for the sunraysia alloys ?
it also states drum brake rear
wrong, bloody wrong
Posted: Fri Feb 22, 2008 5:56 am
by Captain Obvious
every rx i have come across never had p/s (untill i fitted it)mime was a import it a/c (didnt work) but no p/s big bird's rx had p/s fitted from a vortex, and i friend of mine that bought a bog stock rx a few years ago had a/c but no p/s.
i guess coz it was marketed as a sports/ rally car they thought it would need it or something
Posted: Fri Feb 22, 2008 8:22 am
by discopotato03
AC add 30 kilos , no wonder the front ride height lifted after all the underbonnet crap was removed . Does the remaining stuff in near the heater weigh anything significant ?
Mine also has the towbar and prehistoric round I think 4 pin connector .
I must look up what the mid 87 RX's weigh to see if they were any heavier .
Mines supposed to be 1070 kg .
Cheers A .
PS Basically the mid ? 87 on 4 plug Hotwire engine control system does ignition timing as well where the earlier 3 plug system only does EFI . Its timing is controlled like a convention distributor but with nock sensing extras and retard in a separate box .
You could say the early system is EFI and the later full engine management .
If anyone has the road car reviews of these RX's when new would like to see if available on line .
Thanks muchly , A .
Posted: Fri Feb 22, 2008 4:25 pm
by timmo
I've got a modern motor magazine from '86 that has an article on the RX you could borrow it - i dont have a scanner. Theres an online one somewhere on the Group A rally spec model titled "quasi-quattro"
Posted: Fri Feb 22, 2008 5:53 pm
by BlackMale
timmo wrote:I've got a modern motor magazine from '86 that has an article on the RX you could borrow it - i dont have a scanner.
By borrow do you mean that you would be able to photo copy and mail?
Posted: Sat Feb 23, 2008 9:21 am
by timmo
yeah theres a colour photo copier at work i could run some off and mail them if people were extra nice to me! The article is writen by michael stahl (now at wheels) June 1986 Title is "Dual Purpose Dilema.... the suburban struggler becomes a dirt demon!" They're not overly complementary apart from its ability on dirt.
