imprez me
Posted: Thu Jan 10, 2008 8:43 pm
by dibs
hi guys
what hp is a 94 impreza 16 valve and what would be a good price for one with 27000 ks with computer needs crank sensor . what box and is it an easy transplant ???
dibs
Posted: Thu Jan 10, 2008 11:11 pm
by Suby Wan Kenobi
92KW, Crank sensor will set you back $100 second hand, Manual will be dual range with 1.45:1 low, an easy transplant to what?
Posted: Fri Jan 11, 2008 1:58 pm
by dibs
sory guys brumby of course
dibs
Posted: Fri Jan 11, 2008 2:52 pm
by Suby Wan Kenobi
If its AWD it will have the dual range gearbox and its a pretty straight forward swap to a Brumby. You will need to elongate the engine mount holes further outward and make your own gearbox mount other than that you are only stripping the harness. Depending on how you do the conversion you may need to move the battery
Posted: Fri Jan 11, 2008 5:09 pm
by dibs
thanks suby
Posted: Fri Jan 11, 2008 8:11 pm
by Suby Wan Kenobi
If you need any more help just ask
Posted: Fri Jan 11, 2008 9:58 pm
by Bumpty
I learnt about Crank shaft sensors the other day in my bros commonwhore on a four Hr trip (four Hrs from top to bottom of tas... long way for us!)
good luck with the Imprezza!
