Who has EA82T in MY or Brumby?
anyone ? I have a little clearance issue you may be able to assit with, like clearance available above the turbo pipe with Subaru 4WD Turbo cast into it, before agitating the underside of the bonnet
I think stinky does
- brumbyrunner
nil body lift and not planned either
I am using a magnetic pick up tool that is extendable, placing magnet on front throttle body to manifold bolt head I have 187mm from top of bolt head to underside of closed bonnet in my gLat, and hoping like heck I get the same when EA82T eventually goes in.
You got bodylift then ?
I need someone of standard height - I'll try Stinky
The only Brumby’s I have seen with 82T’s have had 2” lift as well, so it difficult for me to comment - sorry.
Whats the problem jono?
Maybe with our collective minds, we can sort it out.
I have found that once I can weld/stick up my Impco 200 gas mixer adapter to the EA82T throttle body it will clear the bonnet of the L series internally , THE BIG BUT is will it also fit under my Brumbys bonnet without reshaping it ala powerbulge ? Considerations already in thought process is which engine mount rubber blocks to use - MY or L - it will be wait and see.
I am thinking to fit up my spare EA82T to my spare Brumby (removing engine off floor and filling some currently wasted space) to do me trial ftment
- subybrumby
I have an 89 brumby with an ea82turbo in it. It has a 3inch lift kit. I am sure without the lift kit, the rear pipe would foul on the firewall. I bought the car with this configuration. The side rails have also been recessed to accomodate the overhead cams. Can supply pics if you want, but need to know exactly what you're after.
nncoolg - no lift ?? you may be able to help esp if you have an extendable aerial style magnet pik up like at RIPCO for a few bucks
subybrumby - don't scare me !! clearance issues were sorted (in my head) as far as general fitment coz I've seen a std height Brumby with EA82T intercooled and he had no obvious rail alterations but didn't look at turbo clearance.
I gotta get some photos of Aarons STi powered Brumby with its very easy looking rail massage that fits twin cam EJ !! (I hear on the grapevine it is for sale @ about $15k - half what it all cost )
- subybrumby
I'll grab a few photos tomorrow if you just bear with me...just for interests sake..Its on blocks at the moment attempting the L series lower control arm mod on the front to fix camber issues. I'll get some photos of the general layout and those problem areas that have been identified for your info..No problem
- subybrumby
Looks like this:-
[ATTACH]631[/ATTACH]
Engine Bay
[ATTACH]629[/ATTACH]
Firewall behind turbo (Close on 3" lift)
[ATTACH]630[/ATTACH]
And recess cut into chassis rail for timing belt
[ATTACH]632[/ATTACH]
Hope this may help you...I purchased the vehicle like this so can't really tell you anything other than you see here.
Engine Bay
Ahoy! Chassis rail mods ahead cappin' !!
