Fish oil in this spot
subarursliberty
Post by subarursliberty » Sat Nov 10, 2007 10:51 pm
Well today I decided to dill to spot weld out of my spare wheel carrier and weld up the holes due to the EJ conversion. Well when I got the plate off there were 2 big rust holes. This car is pretty straight and only has a small amount of rust under the boot seal and a small dot near the rear door. Other than that the car is perfect for rust.
So a friendly suggestion for you all to go out and spay as much fish oil between the spare wheel holder and the fire wall where the tyre sits. Below is a picture. The rust was about where the file and file handle meet. It was about 2 inches round and identical on the other side about a quarter way down the file from the end.
1992 Subaru Liberty Workshop Manual Complete
http://www.ausubaru.com/forum/showthrea ... #post58409
jsubie
Post by jsubie » Fri Nov 16, 2007 8:56 pm
Fish oil is great! It only smells for a short time.
:):confused::p:mad::confused:;):D:-D:???::p
Post by El_Freddo » Fri Nov 16, 2007 9:53 pm
I've heard about this fish oil application. Tell me more - what's the use of this?
subarursliberty
Post by subarursliberty » Sat Nov 17, 2007 11:08 am
El_Freddo wrote:I've heard about this fish oil application. Tell me more - what's the use of this?
Rust protection. Its not a rust killer but can stop rust once it has started.
Post by Alex » Sat Nov 17, 2007 11:13 am
i dont think ive seen a L-series that ISNT rusting in that spare wheel well! Rust converter always works a treat!
howie
Post by howie » Sat Nov 17, 2007 3:32 pm
I have also had Lanolin recommended as it tacks up the same and doesn't smell as much.
Post by El_Freddo » Fri Nov 23, 2007 4:43 pm
Alex wrote:i dont think ive seen a L-series that ISNT rusting in that spare wheel well! Rust converter always works a treat!
Mate, you can check out mine when i'm over there... no rust and no patch job either. - am i not going hard enough?
Post by Alex » Fri Nov 23, 2007 6:01 pm
it means youve got a good wagon :D (not that im calling all the others ****!)
and no....your not going hard enough.
subarursliberty
Post by subarursliberty » Sat Nov 24, 2007 7:22 am
El_Freddo wrote:Mate, you can check out mine when i'm over there... no rust and no patch job either. - am i not going hard enough?
It means you havn't removed the spare wheel carrier. I thought mine was great until I drilled spot welds out nd removed it. I seen it an went holy crap i'm in for a day of welding and grinding.
