looking for speedo check around brisbane
artrixx
Post by artrixx » Mon Oct 22, 2007 10:05 pm
does anyone know if there is still a speedo check set up on the bruce highway north of brisbane, just wondering if my oddometer is miles out and would like to check it over 5 or more k's.
If its not there does anyone know where the main roads dept have set one up around brisbane?
theclick
Post by theclick » Mon Oct 22, 2007 10:14 pm
apparently there is one on the highway out to toowoombah. I can remember seeing one on the way up to gladstone, but dont take my word for it :P
89lseries
Post by 89lseries » Tue Oct 23, 2007 12:20 am
there is an odometer check north of brisbane headin south between anzac rd ish and pine river ish last time i was done. been a while though...mighta changed with all those roadworks...
cheers
Dl l series wagon
2 inch cat back exhuast, 32/36 weber,
CD player, tacho, polyurethane bushes, spotlight, air horns
Ben
Post by Ben » Tue Oct 23, 2007 8:46 am
Gps........................
Please watch before posting!
artrixx
Post by artrixx » Tue Oct 23, 2007 4:25 pm
send me your gps and i will use it?
Post by steptoe » Tue Oct 23, 2007 11:36 pm
ask a sales guy for a demo ??
The Bigfella
Post by The Bigfella » Wed Oct 24, 2007 10:10 am
You can probably rent a GPS from a camping store.
Try it at a range of speeds by the way. I don't know why it works the way it does, but one of my cars is out 6kph from 80 (86 on the speedo is really 80) all the way through to 200 on the speedo (194.1 on the GPS). Private road testing of course.
Post by AlpineRaven » Wed Oct 24, 2007 10:21 pm
Grab an GPS from ebay.. would be worth getting, i use it all the time for work related - distance of kilometres etc and I travel speed camera/time zones and relies on GPS for speed.
My Liberty would be doing 107kmh where the speedcheck says 98 whereabouts GPS says I'm doing 101. SPeed check is estimation purposes.
The Bigfella
Post by The Bigfella » Thu Oct 25, 2007 1:50 pm
I've got four or five GPSs around here (a couple of chartplotters for boats and a couple of handhelds). I've tested the car with 2 x 12 channel GPSs on the dash - and believe me, they are exactly the same with the speed readout - down to the 1/10th kph
SUBYDAZZ
Post by SUBYDAZZ » Tue Nov 06, 2007 11:08 am
GPS is likely to be the most accurate reading you can get. And yes, car speedos vary in accuracy at different speeds. They are usually spot on closest in the range of 70-100km/h from experience and the further either side the larger the error, generally. ADRs require tolerance of +/-4% from memory. And the tyres can be another +/-4% out too! This is why that most radars / speed cameras are set at 10% above the posted limit.
SUBYDAZZ
