crank ventilation EA81- your mods ??
Posted: Mon Jun 18, 2007 10:54 pm
right, lost another oil cap today on the highway (and to the car behind me mit flashing lights "something fell off the truck beside me") on the 'new' engine and i think it is due to some sort of crankcase pressure building up and not blow by as i suspected with the last noisy donk.
some years back i thought i was doin' the right thing by creating a cross flow copying an idea i saw somewhere. It was a paper air filter element from a lawn mower attached to the rhs rocker cover - the idea being to filter any air going through block to the other side lhs rocker cover where the other outlet simply went straight to the PCV valve in the manifold
given that the old manifold is in use on the 'new' motor along with a new air filter for rocker cover. I am wondering if this filter is restricting air flow causing the crankcase pressure. Afterall it was designed to filter air being sucked in by a piston , not to flow naturally.
Or maybe this is typical of an EA81 with nearly 400,000km on it . still runs sweet as
have many modifed their pcv stuff in the past??
