How to correct speedo when larger tyres fitted??
Posted: Thu May 24, 2007 2:12 pm
by Marty
I'm planning on lifting my L series (finally) in the next couple of months. Before I do I just thought I'd look into converting my speedo so that it's still accurate. Has anyone done this either with manufactured kit or something made at home? I'd rather not just use whiteout on the dial. Cheers, Marty.
Posted: Thu May 24, 2007 4:24 pm
by AndrewT
I've seen a couple of L series with a little "gearbox" put inline with the mechanical speedo cable. They have an adjustable ratio in them which can be tuned to make the speedo read correctly.
Don't ask me where to get one as I havn't spent much time trying to track them down, but thats the way to do it.
Posted: Thu May 24, 2007 4:26 pm
by FROG
CHANGE THE SPEEDO DRIVE GEAR IN TRANS CASE... YOU HAVE TO DO THE MATHS THERE ARE A COUPLE AVAILABLE SIZESTHAT I KNOW OF:rolleyes: yours is a 28 or 27 tooth from memory
Posted: Thu May 24, 2007 4:41 pm
by Xtreme_RX
Marks 4WD Adaptors.....
Give them a call....
Posted: Thu May 24, 2007 4:49 pm
by FROG
whittackers speedos wagga wagga---0269216827
Posted: Thu May 24, 2007 4:59 pm
by daveosubi
What do these cost roughly?
I'll be interested in one soon if there not to much, otherwise plan b is the gps and learning the difference
Posted: Thu May 24, 2007 7:26 pm
by stinky
I wouldn't bother, Spend a few days watching a GPS screen and you'll be able to automatically know the difference. I find very little difference in my MY sedan with 27" tyres.
Posted: Thu May 24, 2007 8:08 pm
by Alex
Posted: Thu May 24, 2007 10:57 pm
by AlpineRaven
Better off getting $150 GPS from ebay and watch it - its 99.9% accurate. - but no good in tunnel or under bridges.
Posted: Fri May 25, 2007 1:13 am
by Subafury
just learn how much its out by- usually about 10 or so km's an hour.
Posted: Sat May 26, 2007 1:18 am
by 32ford
castlemaine rod shop will make you a mechanical or electronic adapter to correct speedos
Posted: Sat May 26, 2007 1:29 am
by 90brumby
after speakin wid a few guys wid big tyres i just assume mine is 10% out
