crossmember question
Posted: Sun May 20, 2007 6:17 pm
by Jeff
Has anyone successfully used an ea82t crossmember in a brumby/MY and if so what mods did you do?
Posted: Sun May 20, 2007 6:38 pm
by 90brumby
im sure some people have but it would need mods not sure wat mods tho
Posted: Sun May 20, 2007 9:43 pm
by Brumby Boy
Why would you wanna use it?
Posted: Mon May 21, 2007 9:30 am
was looking under me Brumby last night with same idea as i have a very dirty n/a engine crossmember to look at and thought immediately that the rails are wider so WONT fit, but then what is wrong with using 10mm plate to 'adapt' things.
why fit it? the advantage is not having to butcher a n/a EA81 engine member and strengthen it to fit turbo motor for up pipe clearance issues
Posted: Mon May 21, 2007 1:15 pm
by cruzingbrumby
I saw something about this on USMB, they were talking about moving tit forward to fix the width difference, and also if a lift kit was fitted just using that to compensate for the extra width
Posted: Mon May 21, 2007 5:47 pm
by Jeff
the reason for using it would be to use an ej steering rack and an L series front swaybar as it is hard to fit a brumby swaybar with an awd center diff lock box
Posted: Mon May 21, 2007 9:47 pm
by Brumby Boy
Jeff wrote:the reason for using it would be to use an ej steering rack and an L series front swaybar as it is hard to fit a brumby swaybar with an awd center diff lock box
ok the sway bar i can understand, but you can fit a liberty rack in a brumby crossmember as far as i know
and yea using the turbo crossmember makes sence but i think for all that work to fit it, it would be easier to mod the brumby one, and its not like they are all that rare
Posted: Tue May 22, 2007 6:55 am
by Jeff
I have looked and i dont see how you can fit a liberty rack to an MYcrossmember
Posted: Tue May 22, 2007 6:59 am
by brumbyrunner
I had my front swaybay reshaped to fit around that gearbox but I don't have that 'box in my Brumby anymore. And I gave up on swaybars years ago.
