inside bellhousing of 5 spd 4WD box, the input shaft clutch bearing slide sleeve nose whatever that is held in by three bolts..how do you remove this bit ?? is there a bearing and seal in there ? is the sleeve a tight fit over the bearing ??
i have attempted to remove to clean dirt out of the splines as last owner kept it outside his shed on the ground, rainfall and mud has splashed up in there and i wanna protect internal componenets as much as possible from premature wear
thanks,
L gearbox ?? front clutch bearing slide
- Suby Wan Kenobi
