ej20t question
Posted: Fri May 04, 2007 8:56 pm
by Jeff
Just wondering if any of the people with ej20 turbos in MYs have any problems with heat buildup in the engine bay I am looking at building an ej brumby with the intension of towing a small camper trailer on long trips and havnt made up my mind whether to go turbo or na ?
Also would the brumby radiator be suitable for this application?
Jeff
Posted: Fri May 04, 2007 9:00 pm
by seagull
you would be better to get a Ej22 or the ej25 motor n/a
Turbo for towing pass
Posted: Fri May 04, 2007 9:58 pm
by Gannon
Definately upgrade your radiator to a lib type
Posted: Fri May 04, 2007 10:20 pm
by brumbyrunner
If you're not chasing acceleration, Id go non-turbo for driveability and economy.
Posted: Fri May 04, 2007 11:34 pm
by Suba
seagull wrote:you would be better to get a Ej22 or the ej25 motor n/a
We towed a camper 11,000 k's over to QLD and back and got really good economy with the ej20.
Mike.
Posted: Fri May 04, 2007 11:49 pm
by Outback bloke
Turbo is far superior to NA for towing. I sat down and typed a huge story about it and some how deleted it. Not going to do it again.
Jeff, in short use a better radiator than the MY one. New custom, or modify your radiator support and fit in the EJ one. Heat is not a problem in the engine bay at all. Go the turbo. If you want fuel economy buy a Fiori.
Posted: Sat May 05, 2007 4:30 pm
by Jeff
Thanks for the replys I currently tow a trailer with an awd ea81t brumby with no probs just not enough power for me so i will probably go with the turbo and also i have all the parts here for the turbo so it saves me sourcing an NA engine and loom etc
Jeff
PS i will be seeking expressions of interest in my current brumby shortly
Posted: Sat May 05, 2007 9:16 pm
by 90brumby
will you be sell the brumby complete
Posted: Sun May 06, 2007 8:16 am
by Jeff
Yes it has an ea81t engine ,5speed awd box with centre diff lock [including Lseries low range] 4 wheelLseries disc brakes[including fronts] and a liberty power booster ,a 2inch lift kit and 14 inch sunraisers etc anyway i will list any other things when i sell it as this is off topic
Posted: Sun May 06, 2007 4:01 pm
by Ben
Jeff, if heat is a problem put a cosworth style vent facing backwards in the bonnet, nothing overstated but will help with airflow through the radiator and out of the engine bay.
