EA81/EA82 eng xmember difference ??
Post by steptoe » Tue May 01, 2007 9:44 am
can anyone describe just what the difference is between EA81 and EA82 engine mount holes on the engine cross member. are the holes simply elongated further out or redrilled a fair bit further away ?
I have an EA82 member I can get at to measure to compare somehow if you have an EA81 to do same if that's gonna help
Suby Wan Kenobi
Post by Suby Wan Kenobi » Tue May 01, 2007 7:20 pm
The holes for the EA82 are further apart, to put an EA82 into where an EA81 was you can simply elongate the holes using a die grinder
The long road ahead
Post by steptoe » Wed May 02, 2007 9:47 am
SWK to the rescue again ! thanks
that sounds better than the others, not here, who have said ...
1. use the L series crossmember
2. stick L over MY and drill through
I have made templates of L Series turbo engine crossmember cutaway pressing for the turbo pipe and gonna practice on n/a L xmember first.
