Exhaust fumes
Timmeh
Exhaust fumes
Post by Timmeh » Thu Apr 12, 2007 6:00 pm
Something I've noticed for a while now but kinda ignored is that When I first start my brumby up, there is a strong smell of exhaust fumes in the cab which goes away after she warms up a bit. I noticed also that this became worse after I upgraded my pipes to 2 1/2 inch. couild this possible be an indication of slightly dodgy head gaskets? Should I start worrying and rounding up new gaskets? And on a slighjtly different topic, can heads from any other subie engine mate up with the ea81 engine? I.E. Could I swap ej18 heads for the factory ones? If so, any advantages or just a pain in the arse?
'92 Brumby - 2 1/2 exhaust, 6 speaker 800 watt stereo, looking for headers and 5 lug hubs.
Brumby Boy
Post by Brumby Boy » Thu Apr 12, 2007 8:11 pm
as for the exhaust fumes i dont know, all i can sujest is that you make sure your pipes are all welded proberly and all gaskets in the exhaust system are ok,
as for the heads, no no other heads will fit this motor, well not that will work, if its performance your after your best bet would be an ej22 convert or if the budget allows, a ej20 turbo convert
RIP 1992 Brumby
