1995 Phase 1 EJ22 wiring diagram
Posted: Sun Feb 10, 2019 5:08 pm
Wondering if anyone has a wiring diagram for a 1995 Subaru Legacy 2.2 (NZ-new)? My flatmate has purchased it to re-power his new jetboat with (is running a carbed EJ18 at the moment and it's a little gutless). The aim is to switch to an MPFI EJ22. Both motors are phase 1 SOHC EJ motors so is bolt-in.
The problem is the wiring - the Legacy is obviously the newer post-94 shape and as such has a different ECU and wiring to the earlier shape Legacies (favoured for L series EJ swaps).
Between the two of us we've figured out most of the wiring (have already got the engine and harness out) but are unable to ID some of the critical wires eg fuel pump and starter. Unfortunately we didn't think to trace & label before pulling the engine & loom...
I've dug through the old tech manual threads with no luck.
So does anyone have a wiring diagram for this bastard of a car? The VIN is JF1BG7KJ4SG009993 if that helps. Cheers.
