efi v's carb questions
artrixx
Post by artrixx » Sun Aug 13, 2006 1:43 pm
would it be fair to assume that a fuel injected L-Series touring wagon with diff ratio they have would be a better driver with larger wheels than a carb version sports wagon. would it be more gruntier and would it be better on fuel? i have the chance of picking up a touring wagon of the same age as my sportswagon and i am wanting some opinions from those that may know
MUDRAT
Post by MUDRAT » Sun Aug 13, 2006 2:07 pm
The EFI L-series is a lot smoother, seems to have more bottom end and has better driveability than the carby version, but as far as I'm aware diff ratios should be the same? My GL was a 3.9:1 carby L-series.
The EFI motor in my opinion is much better than the carby one.
artrixx
Post by artrixx » Sun Aug 13, 2006 3:39 pm
i thought the touring wagons had a 3.9 diff and the sportswagons had a 3.7.
or maybe its the other way around. anyway i had a memory of people saying the touring wagon gearbox and diff was better for cars with lifts and bigger wheels......??
do the efi's return better fuel economy , as a general rule?
MUDRAT
Post by MUDRAT » Sun Aug 13, 2006 4:13 pm
I'll say marginally from what I've seen.
stinky
Post by stinky » Sun Aug 13, 2006 5:19 pm
The EFI should really come into it's own on really steep ascents where the carby would tend to starve out. when I put the EJ into my MY I parked on a really extreme hill and it sat there idling happily, the ea81 would have died.
Suby Wan Kenobi
Post by Suby Wan Kenobi » Sun Aug 13, 2006 5:38 pm
The EFI versions are more responsive and have more power than the carb engines
The long road ahead
artrixx
Post by artrixx » Sun Aug 13, 2006 9:07 pm
thats interesting would you say it was a major improvement or just a minor improvement in power also what about the effect of the different diff ratios on the touring wagons. would that help push a car along with larger wheels.
MUDRAT
Post by MUDRAT » Sun Aug 13, 2006 10:26 pm
To be honest with you, I can't tell between a 3.9 and a 3.7.
Suby Wan Kenobi
Post by Suby Wan Kenobi » Sun Aug 13, 2006 10:48 pm
There is a major difference in performance in the EFI from the carb version but as far as diff ratio goes the 3.7 box had lower ratio gears to compensate for the taller ratio.
The long road ahead
KERAZY
Post by KERAZY » Mon Aug 14, 2006 9:42 pm
is gruntier a word?
Suby Wan Kenobi
Post by Suby Wan Kenobi » Mon Aug 14, 2006 11:39 pm
Indeed it is
The long road ahead
