L series rear camber
Post by AndrewT » Wed Jul 19, 2006 9:44 am
I posted about this once before but I think it was lost with the old forum data...
Can somebody please re-post that picture which explains how to adjust the camber of the rear wheels in an L series?
thanks.
Suby Wan Kenobi
Post by Suby Wan Kenobi » Wed Jul 19, 2006 11:17 am
You dont really need a pic, jack the car up at the rear and take the wheels off. You will see 3 bolts infront of the drum or disc, undo them slightly and let the swing arm drop to the old bolt shaddows (may or may not be visable) then retighten do the same for the other side. if you dont have any luck it could end up being the inner pivot bushes are worn.
The long road ahead
GTlegs
Post by GTlegs » Wed Jul 19, 2006 5:09 pm
How do you actually make the camber more negative? It seems to be quite positive stock.
smoov
Post by smoov » Wed Jul 19, 2006 5:52 pm
undo the bolts and push the wheel up :roll:
1998 Subaru Legacy GTB
MUDRAT
Post by MUDRAT » Wed Jul 19, 2006 7:02 pm
The best way to do it is using a trolly jack under the rear diff, loosen the bolts and play around with the weight of the car or the weight of the wheels until you're happy.
