Removing Speedo Cable from Gearbox.
Gazza01
Post by Gazza01 » Fri Jan 20, 2017 8:04 am
Removing gear box having difficulty removing speedo cable from side gearbox. Is it screwed in or is it push in. I dont want damage it .
Post by TOONGA » Fri Jan 20, 2017 10:45 am
It is screwed in, getting it out is easy just use a small shifter ... getting it back in depends on how clean it was when you took it out ... take your time and make sure there is no sand /mud debris around the cable head.
Post by El_Freddo » Sat Jan 21, 2017 2:07 am
Clean real good first.
17mm spanner to get it out from memory, turn, rotate spanner, turn, rotate spanner. You'll know what I mean ;)
One of I'm used to turn off centre as it came out. Also be careful as the bit that screws I to the gearbox is plastic. Once the Hex shape is rounded the cable is cactus.
All the best with it ;)
Gazza01
Post by Gazza01 » Sat Jan 21, 2017 6:41 am
Thanks Guys.
