Radiator reccomendations
RubysueEA82
Post by RubysueEA82 » Tue Apr 05, 2016 10:12 am
G'day blokes,
I've tried the cheap eBay ally radiator & found the mounts don't line up. Doesn't do what it says on the tin so I'm sending it back on general principal.
Who's got any idea on what I should get? Full copper/brass unit? Locally made alloy one? I'm in Adelaide so adrad might be helpful.
Does anyone else find it amusing that a new heater core is $385 & a complete alloy radiator can be had for $200 less!
Nubaru
Post by Nubaru » Wed Apr 06, 2016 8:06 am
I reckon you should keep it and buy a nutsert kit
Post by TOONGA » Wed Apr 06, 2016 9:27 am
The heater cores are not "mass" produced as such so they cost more to make but yes 385 dollars is rich.
I do know when you type in universal heater core you get hits like this
http://www.ebay.com.au/itm/Universal-He ... SwcF9UWuYO
Post by El_Freddo » Thu Apr 07, 2016 1:32 am
Jules grab your specks ;)
A radiator is needed, not a heater core. But that said I've paid more for an all brass copper heater core than I had on a radiator until last summer...
As for radiator go with what you need. For an ea82 an all alloy probably isn't needed. If going bush a brass/copper unit would be good in the event it needs repair beyond the black stump - if you carry a soldering kit.
Dual core could be a good idea if you run in hot temps all the time.
While you're at it a new water pump and genuine thermostat to make sure the major cooling parts are in new condition with the radiator.
Nubaru
Post by Nubaru » Thu Apr 07, 2016 8:15 am
El_Freddo wrote:Jules grab your specks ;)
and seeing though you are in correction mode it might not be general principal - principle maybe?
Post by El_Freddo » Thu Apr 07, 2016 10:07 am
So many spelling mistakes on the forum I'm glad I'm not a moderator otherwise the literacy teacher within would probably end up OCD about it!
