if there is, someone find it and stick it here please !
Not really a forum for quick times except maybe on the dirt or in the mud
But a tar run nought to a hunge and only if you run it to the 100 kph of a GPS checked speedo I reckon. Otherwise no point is there ?
Been in my EA82M LPG powered Brum with 5 speed 4WD DR box and used car clock to measure a 0 to 100 in 22 seconds. Then on another stretch similar uphill incline in my EA81 20/60 cammed 4 speed LPG Brum snorting through a spfi inlet manifold and wha....?? 30 seconds ?? Another try, still with full tank and load in the back 0 to 100 18 seconds.
Doing this in prep for a 5 speeder into the EA81 see if get anything other than an extra shift up to top gear
 Unless I drive 2 hours north to the only drag strip in (out of) town
 need to GPS check my new to this beast rim and tyre combo - 175.70.13 GoodBoots - I may be leading myself on
