The EA chassis and excessive power.
MY_STI
Post by MY_STI » Wed Jun 07, 2006 6:17 pm
More so the L series, how does the chassis take it? What would I expect to bend/break in a 13s 1/4.
keen to hear tales of twisted diff hangers or worse...
BlackMale
Post by BlackMale » Wed Jun 07, 2006 6:35 pm
Are you kidding me… its an L series!!! :lol:
QikRX
Post by QikRX » Wed Jun 07, 2006 6:43 pm
I have had my whole front end seam welded from when it was rallied & also have a cross brace as well. In it's current tune, mine is running mid 13's but have run a high 12 with a larger turbo & more boost etc.
Haven't had any probs with chassis flex, only mechanical dramas :x
tim_81coupe
Post by tim_81coupe » Wed Jun 07, 2006 7:23 pm
I have a stock MY coupe that although it has never backed it up on the strip is definitely in low 13's territory.
Never had a single problem with the chassis. Actually nothing apart from rear axles and the clutch has had a rough time with the horsepower.
82 MY Wagon, EJ20G
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
Chris_Rogers
Post by Chris_Rogers » Wed Jun 07, 2006 9:05 pm
give me 6 weeks and I'll be able to tell you :)
Audio Express
1987 HR31 Nissan skyline
1990 R32 Nissan Skyline GTS4
tim_81coupe
Post by tim_81coupe » Wed Jun 07, 2006 9:08 pm
Oh I should've mentioned I did twist up my diff hanger in the first week.
Welded two together and haven't looked back since...
82 MY Wagon, EJ20G
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
damo666
Post by damo666 » Wed Jun 07, 2006 9:12 pm
Where the top chassis rail meets the front windscreen is a definite weak area - everything foward of the windscreen likes to flex away from the body! (the factory RX rallycars had some fairly seroius plating in this area).
Seam welding the front strut towers and lower & upper chassis rails is a good idea. Plating &/or triangulating the top rail back to the body is a better idea!
wagonist
Post by wagonist » Wed Jun 07, 2006 9:54 pm
Now I find out AFTER I've had the engine bay painted.... :?
Would've been perfect time to have it welded.
Current rides:
JDM GTII Touring wagon
Previous rides:
96 Toyota Caldina wagon
MY_STI
Post by MY_STI » Wed Jun 07, 2006 9:55 pm
Thanks guys,
Have seamwelded most of the frontend, have added reinforcing plates around mention areas, triangulated peice between the top rail and the body done. Not sure if it my imagination but it feels heaps tighter (shake test, highly accurate...)
Was checking if there was anything else that should be taken care of when its a bare shell, havent touched the back yet, worth worring about?
damo666
Post by damo666 » Wed Jun 07, 2006 10:37 pm
I wouldnt bother with anything else, especially if its a street driven car that occassionally sees the strip - it should hold up fine as is.
vincentvega
Post by vincentvega » Thu Jun 08, 2006 9:07 am
talk to oversteer, he had one of the quicker L wagons around
subelover
Post by subelover » Thu Jun 08, 2006 10:30 am
hi my_sti a while back a member found a rx rally car parts guide and it has part numbers and mods for the group a rally cars ect. it has a chassis strengthening kit for the car ill email u the info
cheers BEN
Ben
Post by Ben » Fri Jun 09, 2006 10:11 pm
tim_81coupe wrote:I have a stock MY coupe that although it has never backed it up on the strip is definitely in low 13's territory.
Teehee... That's funny :lol:
Please watch before posting!
tim_81coupe
Post by tim_81coupe » Fri Jun 09, 2006 10:52 pm
I meant stock as in body.... :P
Does say EA81 on the bonnet...
82 MY Wagon, EJ20G
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
fredsub
Post by fredsub » Sat Jun 10, 2006 10:00 am
subelover wrote:hi my_sti a while back a member found a rx rally car parts guide and it has part numbers and mods for the group a rally cars ect. it has a chassis strengthening kit for the car ill email u the info
cheers BEN
If that info can be quoted here,I think we'll all be interested in what that had to say, Thanks!
MY_STI
Post by MY_STI » Sat Jun 10, 2006 5:43 pm
subelover
Post by subelover » Mon Jun 12, 2006 8:53 am
hey Will, hope that guide was of some help i would've put the guide on to the site to download but couldnt work it out. pretty good read i think. i like the mods to the intake and the specs for the motor good read. anyway hope it helped...
cheers BEN
fredsub
Post by fredsub » Mon Jun 12, 2006 9:59 am
thanks for that, looks like my_sti is hosting it.
Interesting the odd bits for reinforcing ..A and B, but i guess it makes sense..
I wonder if for B, you need to remove the rain channel first (can't see how?) before applying the plate.......
