Brumby Ignition Module.
I'm looking to buy a new Ignition Module for my 91 Brumby. When I do a check I see Tridon Subaru Brumby Ignition Module is TIM004. However further checks also show CM417 to fit Brumby and they r asking a leg and a arm $75 plus, but I see Subaru L series carby version show E12-61 with two connecting points same as CM417 and TIM004 selling for $59. Can anyone tell me if E12-61 is same animal as CM417 & TIM004.
Did a search of the RAE site and they show that both the Subaru Brumby and the L series 82-94 take the same identical Ignition Distributor control Module RAE use the number IM120 . Tridon use the number TIM004 . Other numbers for the same Module are CM417 and E12-61 and its gets a bit confusing when u go on ebay and u only seem to come up with either CM417 or E12-61 and in most cases they only indicate just Brumby or L series when in fact all these Module numbers refer to both vehicles and are just a manufactures numbers . I just did a check of a friends 87 Brumby and his module has the number E12-61 stamped on it. Guess all this mind bending stuff stops a man from going brain dead.
