OK, next project to see completed ....
Posted: Sat Jan 31, 2015 10:02 pm
should be either my EA82T Brumby or Fujifans EA82T build...now that Tweety is all up and running quite respectably :)
My turbo steed should be on the road very soon, just in NA LPG EA81 form for starters, with new head gaskets, front brakes, rear shocks, L Series struts and strut tops, sports dash with tacho and oil presure gauge instead of fuel and temp gauges....listening to Maria play tonight reminded me I have not driven my EA82T that sounds like her..exhalations ....since I .....stripped my turbo sedan :) . Gives a similar deep breathe noise as turbo spins between gears
any other projects we don't know about ??
Posted: Fri Feb 06, 2015 11:51 pm
Not sure if you're mumbling to yourself or if we'll race to finish projects? :p
Anyway, I'm sure others know about this one as I've slathered it in several places on the forum - Ruby Scoo's gearbox rebuild. Swapping out the RX turb gearset with blown 2nd for a neat beefy set of SG gears and a Gen 2 fifth gear ratio of 0.87 - hit a roadblock on this one atm, plus work is taking up all of my time :evil:
Looking forward to having this back together and my offroader back in the bush operational again!
Other minor projects - replace steering boots and a cv boot on Sunnie the Brumby and
Fixing oil leaks on Redback - first going with an oil pump resell kit and front crank seal then eventually do the sump gasket. Should've done it when the HGs were done and the engine was on a stand...
