With the previous arrangement the radiator for the ea81 was up front of the trike, with two 10 inch thermo fans both pullers. Also of course were 2x stainless steel pipes for coolant travel which also helped keep things cool. The Alfa 33 radiator facing the front, imagine you are sitting on the trike seat. The inlet on the LHS was about half way up the radiator. The exit on the RHS is at the top of the radiator. The thermo fan switch was on the RHS half way up the sides. The thermatic fan switch is a 87 on 82 degrees off brass type.
The pressurised overflow bottle was at the back off the heater hoses. Air blockages were an issue and summer time heat on my legs was unbearable.
Now imagine holding onto the radiator from the seat and spinning 180 degrees and mounting it at the rear of the engine. The radiator hoses are in effect reversed. The top hose from the SPFI thermostat housing goes through a temperature sender to the top high up radiator inlet. The thermatic fan switch is now half way down that side. The radiator exit is now half way down on the other side ideal for the route to the water pump. The coolant pressurised overflow bottle is off the top radiator hose= no air blocks. We have one 10 inch fan puller and one 12 inch fan pusher.
With the previous set up the thermatic fans would switch on at 90 degrees and off at 82. Exactly as I wanted. Even though there was a long way for the coolant to travel and that switch was on the "cool" side of the radiator. Though the digital temp sender has never moved from post thermostat housing area.
Now when running fully warmed up, the digital temp gauge, which has its sender always at the top of the thermostat housing, creeps up to 94 degrees even 98. Then the thermatic fan cuts in which is mounted now only 200mm below the digital sender. Could there be 7-9 degrees difference between those components?
So my real concern is that my digital temp gauge now reads very high. And is this a concern? Would there be 98 degrees at the location immediately post thermostat in all engines?
I am about to install a heater core with a 10 inch fan as insurance the engine remains at temps in the 80's.
Sorry for the confusion- it isnt easy explaining.
The picture depicts the top radiator hose currently. In that hose is a unit that carries- the sender for the digital temp gauge and the fitting for the coolant reservoir. You can see the thermatic fan sender further down.
