CV boot.help
Ben james
CV boot.help
Post by Ben james » Tue Nov 04, 2014 7:04 pm
hey guyz last weekend i went 4wding and
Noticed that i shredded my drive shaft CV joint boot.
so all the lube has sprayed every were. im guessing that's bad.
so does any one know apart from ebay were i can get a new
boot asap. and how hard are thay to replace. cheers.
yarney
Post by yarney » Tue Nov 04, 2014 7:36 pm
Most workshops will replace cv boots and not charge that much
They are cheap to buy the boots on there own around $17-$25
If you have been 4wding with the boot broken and got dirt inside you may as well kiss them good bye:(
If you haven't done them before good luck, It's always good to watch someone change a boot first. But it's a messy job
Jan
Ben james
Post by Ben james » Tue Nov 04, 2014 9:15 pm
thanks for info bro. and yes i was 4wdin poped hood to
have a look and noticed grease everywhere.
julian
Post by julian » Wed Nov 05, 2014 12:31 pm
If you 4wd a lot it might be worth buying a new/rebuilt complete shaft.
They are not expensive and become a "wear item" if you have a lift that drastically alters your CV angle. Once you have a spare you can get it rebuilt and rebooted and you are ready to swap in a whole new shaft as soon as you pop the next one!
Julian
2004 Outback H6
2004 Forester XS
Organ donation saves lives
