Which carburetor is this
Posted: Sat Aug 16, 2014 12:37 am
by nairobery
Saw this at the junkyard
Sent from my MT2L03 using Tapatalk 2
Posted: Sat Aug 16, 2014 8:01 am
you saw it and didn't grab it ?
There was either EA71 twins or EA81 twins and the difference is in the manifold length - EA71 won't fit on EA81. The EA81 twins will also fit on EA82.
The measure between each head is pretty obvious. The EA81 twins have something like DCG306 etched onto them , but hard to see unless clean. Don't sound too excited at the yard - price may go up :
Posted: Sat Aug 16, 2014 12:05 pm
by sven '2'
Ea71
Posted: Sat Aug 16, 2014 4:10 pm
was thinking looked a bit different in the top cover screws and PCV inlet but I think 'bery has got an EA71 in his L Series !
just measured an EA82 inlet manifold I thought I didn't have. 524mm between centres of each of the outermost stud holes
Posted: Fri Aug 22, 2014 12:00 pm
And.... any follow up ??
Posted: Thu Oct 30, 2014 3:17 pm
by nairobery
steptoe wrote:And.... any follow up ??
The guy at the yard told me it would kill me on fuel, so I just didn't even look at it again. What do you think
Posted: Fri Oct 31, 2014 6:13 am
I got better fuel efficiency with my twins, and same with Willy and his twins on EA81 got his down to 6.5 l per 100km. You gotta go back and snap them up if no one else has!
Posted: Fri Oct 31, 2014 1:18 pm
by nairobery
steptoe wrote:I got better fuel efficiency with my twins, and same with Willy and his twins on EA81 got his down to 6.5 l per 100km. You gotta go back and snap them up if no one else has!
Wow really ok I will call him up if they haven't been taken am getting them. Thanks
Posted: Fri Oct 31, 2014 3:27 pm
by sublime
Yes a very common furphy that twin carbs result in poor fuel economy, that is simply not experienced in practice.
Posted: Fri Oct 31, 2014 6:16 pm
by nairobery
sven '2' wrote:Ea71
He told me it's off ea65 and won't fit my ea71
Now am just thinking about putting ea65 heads and get an ea65 camshaft as well.
Read somewhere on a forum that the ea65 head flows better and would improve performance.
Would like to try it out just don't know how true that is.
Posted: Sat Nov 01, 2014 9:07 pm
by sublime
nairobery wrote:He told me it's off ea65 and won't fit my ea71
Even if it is from an EA65 it is based on the EA71 so I would imagine the manifold will have the same spacing. I doubt very much that the EA65 has its own manifold. Of course I could be wrong but my understanding is the EA65 is a 1300cc version of the EA71 so I cannot see it using a different intake manifold.
If you can get measurements of the bolt holes I can compare it with mine if you like.
Do not confuse the EA65 with the EA63. Early EA63 1400cc engines had dual exhaust ports on opposite sides of the heads, one on the front and one on the back for each head (so 4 ports in total for the engine). Not the single, siamesed exhaust port design of late EA63, EA71, EA65 and EA81 engines. All of which are located underneath the heads. The original EA63 also and reversed valves, hence the different camshaft and, of course, better 'breathing'.
