Brumby fuel pump
Brumby fuel pump
Looking for a Brumby fuel pump at wreckers. Anyone out there know any other make of vehicle with a compatable fuel pump.
- TOONGA
Ebay has this model which can be adapted to fit where the brumby fuel pump fits
http://www.ebay.com/itm/12V-Universal-H ... 5664f96406
- justincase41
Depends on the year of the Brumby. Early up in the engine bar and later down the back.Cliff R wrote:Where is the fuel pump mounted.
Under the bonnet behind the LH front strut tower or in the rear near the fuel tank.
What the.. the fuel pump is just to the left of the fuel pumpjustincase41 wrote:If its still the original fuel pump, its located at the rear end underneath the tray area, to the left of the fuel pump
- justincase41
LOL.. so see if I get this right.. You are "just in case of number 41 of scotch"justincase41 wrote:A few to many scotches tonight
Hahaha.. thanks for the laugh but a little upset you're not sharing
Yeah the Facet pump is available in many different manufacture's cars, so just ask around at the wreckers but IMO why would you buy secondhand when you can buy this one TOONGA has suggested?
Sorry, I haven't been on the forum for a while.
What I was getting at, if the pump is mounted in the engine bay behind the front LH strut then this is almost a direct fit for the original diaphragm pump. The only mod I had to do was change the rubber spacers on the original pump bracket and sort out the filter bracket.
The main difference between the original and the new pump is the pump head diameter. The new one is a bit bigger in diameter so can rub in a few places.
New pump fitted
Another one of the new pump fitted
New pump fitted
