Help with brake pad change
Posted: Fri Mar 28, 2014 9:13 am
by Vortex75
Hi guys, want to change the front pads on my Vortex and I was reading my service manual and it says I need two special tools to push the piston back in the calliper. Every other car I've had I've just take the calliper off and used a vice but it says DON'T do that as it could stuff the thread. Where can I get these special tools (926430000) and (92440000). Thanks
Canny
Posted: Fri Mar 28, 2014 9:21 pm
by TOONGA
Take an old 19mm socket and cut 2 10mm grooves in it, then 2 more at 90 degrees to the first cuts. so you end up with 2 prongs on the end of the socket and presto you have the special tool.
Posted: Fri Mar 28, 2014 9:57 pm
or any SCA, autopro , repco joint should have the tool.
The pistons are about 53mm in diameter and has two recesses at say six and 12 o'clock to take the prongs of the tool and wind it in clockwise and some brute strength
Posted: Fri Mar 28, 2014 10:02 pm
by Vortex75
Thanks guys, it's says to take the handbrake cable off but doesn't really show how. Does it just come of with a pair of pliers?
Canny
Posted: Fri Mar 28, 2014 10:28 pm
by TOONGA
Vortex75 wrote:Thanks guys, it's says to take the handbrake cable off but doesn't really show how. Does it just come of with a pair of pliers?
Canny
Don't unless you want to spend half a day putting the cables back on.
There is no need to remove the hand brake cables just make sure it isn't on when you do the brakes. As well make sure the car is well supported and on flat ground when you do this job.
https://www.youtube.com/watch?v=A129SM9 ... EqT2Z1HEtA
Posted: Fri Mar 28, 2014 10:48 pm
by Vortex75
Thx mate. Strange having the handbrake operating on the front brakes.
Canny
Posted: Fri Mar 28, 2014 11:15 pm
by Silverbullet
Vortex75 wrote:Thx mate. Strange having the handbrake operating on the front brakes.
Canny
Yeah, means we can't drift our Subies around every roundabout
Posted: Thu Apr 17, 2014 7:13 am
by Smokey
I've used the round noses of a pair of multigrips adjusted to the required width. Worked fine.
Though I've had the rubber want to not turn with the piston, twisting it and threatening to rip. Quarter turn then a small one eighth in the wrong/back direction each turn seemed to keep it straight.
Sent from my Nexus 5 using Tapatalk
