Paint Code
Posted: Sat Sep 21, 2013 5:32 pm
by badga880
hello all,
did a search for paint codes I have a white 1992 brumby ute with the paint code label missing...but the info coming I am unable to decipher. Ok some call me thick but would anyone know if I ring Subaru with the VIN will they be able to locate the colour code.. or any other place I am on the Gold Coast I only need a touch up spray can
Thanks
Posted: Sat Sep 21, 2013 6:33 pm
bloody paint codes ...the one on my white 92 Brumby came up as not white style tints in the mix....thought we had it as 254 , but just then close inspection on the partial remains of the silver paint code sticker ....looks like 264.
Painter made his own mix to match in the end.
254 or 264 help ?
Posted: Sat Sep 21, 2013 9:08 pm
by Bantum
I found this site on the AUSubaru Wiki :
http://www.paintscratch.com/touch_up_paint/Subaru/
It has good references, but doesn't cover all models ... :(
Cheers, Bantum ...
Posted: Sun Sep 22, 2013 5:44 am
by badga880
Thank you for the info cannot find brumby on paintscratch.com I will take both those codes 264 &254 and see if I get a close match it only has to last me a few months Thanks again
Posted: Sun Sep 22, 2013 7:17 am
by Gone Fishing
Dont know if it helps mate but the paint code on my 84 Brumby ute is 241. If you go to some of the paint shops they can match the paint code and then put it into a spray can for you. I had this done here in Ayr for some touch ups.
Posted: Sun Sep 22, 2013 10:09 am
by badga880
Thanks again will try all 3 paint codes
Posted: Sun Sep 22, 2013 1:15 pm
by Bantum
Did you check your VIN ?
showthread.php?t=20175
It should have some info on what model it is at least ... ;)
Cheers, Bantum ...
Posted: Sun Sep 22, 2013 4:20 pm
by badga880
Yep checked vin only vin number says pick up GVM but nothing like the plate in the pic of the link that bantum put up will ring Subaru with vin Thanks
