97 impreza ej16 cam bolt torque
apfreds
Post by apfreds » Wed Jul 24, 2013 10:57 pm
I removed both cam pulleys to replace the cam seals on my 97' Impreza ej16 & now I'm looking all over Google/Youtube & can not for the life of me find the Torque settings for the cam pulley bolts, I have the FSM's for both 93-96 & 97-98 Impreza's, but they only give me DOHC torque info, please help, It's getting late and I want to finish installing my timing belt tonight.
cheers, Aaron.
also if there's a pdf download somewhere with SOHC diagrams, that would be amazing.
Post by El_Freddo » Wed Jul 24, 2013 11:14 pm
I'd say that the torque specs for the DOHC cams will be the same as the SOHC.
I've not gone with torque specs other than "really tight" with a socket and breaker bar...
apfreds
Post by apfreds » Thu Jul 25, 2013 12:15 am
thanks El_Freddo for replying,
I was thinking that, I found the torque settings for the 1.8 sohc, just going to go with that, throwing on a bit of permatex threadlock to make sure too.
you don't by any chance know the crank bolt torque for the 1.6? that will be my next mission.
Post by El_Freddo » Tue Jul 30, 2013 7:29 pm
If you have a haynes or gregory's manual it'll be in there ;)
I don't know where mine is so I can't do a quick reference for you...
