Brumby indicator issues
Posted: Sat Jun 01, 2013 1:37 pm
by Backyard_Brumby
Hi everyone,
Having issues with the brumby indicators. They first cut out completely while driving down the road, after chasing fuses and the likes they suddenly decided to start working again. They worked for a couple of trips then cut out again, it seems to be a intermittent fault. I have checked every corner and re done the wiring for each indicator making sure they all have a good connection. All bulbs are working fine as well. The fuse did blow at one point but at the moment they aren't working and the fuse is perfectly fine.
I purchased a flasher unit from supercheap with the same ratings and it didn't make a difference.
So any ideas? :confused:
Next step I am thinking about ordering a flasher unit that I know is the right part. When I went to remove the flasher unit this morning it was quite hot, nothing else in the car was hot and the ignition hadn't been turned on at all.
So once again I call on the brains trust on here, what would you look at next?
Turn Return ...
Posted: Sat Jun 01, 2013 7:17 pm
by Bantum
Might be worth checking this out ...
Turn Indicator Fix
Cheers, Bantum ...
Posted: Sun Jun 02, 2013 8:30 am
James, you could help us if you tel us which Brumby as I see MY avatar pic, UG in your sig.
I'd say not seen incorrect rated flasher doo dad yet for these old simpletons. Id be blaming the switch itself, pull steering wheel off to inspect, check its riveted wires if any, check the harness plug for good measure. My flasher can got a drowning with windscreen water leak so now secure can so plug pins face down.
If you have a tow connection check the plug for mud, check the wiring for body rub ....
Posted: Sun Jun 02, 2013 5:29 pm
by Backyard_Brumby
Thanks for the advice guys, turned out to be the flasher unit. The one I purchased from supercheap although it fit the plug did not work. After taking the flasher unit apart I noticed a connection was loose so re soldered it and running perfectly now :)
