knock sensor
- Mitchhsj
knock sensor
hi guys i got another question for ya
my ea82T i just converted into my L wags has no knock sensor on it that plugs into the small loom that goes to the dizzy..is the sensor needed for the car to oparate correctly ?? my motor is running strange, when under boost the motor is hesitating through the power curve like its cutting fuel in and out but its not pinning... I'm worried it has something to do with the computer.. i have changed the MAF sensor/ whole dizzy and coil and still the same, but i do have the timing advanced 3 markings past 10.. i have the rx fuel pump in it but the L series lines are smaller as are the outlets on the tank.. any imputs would be awesome , thanks heaps had my head in the motor for 2 days
Only by running an aftermarket ecu.
