stuck in 2nd
wrx_nut
stuck in 2nd
Post by wrx_nut » Tue May 16, 2006 7:28 pm
my mate just picked a liberty up pretty cheap...
its a liberty sedan not sure what year but it has a 5speed AWD gearbox which is stuck in 2nd gear....anyone ever heard of this or happend to you before???
im going to have a look to see exactly what it is and what not
just thought id ask...
cheers
wrx_nut
SCOOBIDOO
Post by SCOOBIDOO » Tue May 16, 2006 8:30 pm
It could be a loose or faulty selecter ,check underneath to make sure everything is bolted to the box and body....make sure there are no sticks or anything else jammed in the shifter linkage, if all is good i would say your synchroniser hub in the box is jammed on to second gear...if this is the case its probably damaged too! good luck though..
Post by steptoe » Wed May 17, 2006 2:38 pm
any signs of 'boy racer' on car
sounds like shift change done too qwik and in the synchro
Subaman
Post by Subaman » Wed May 17, 2006 5:10 pm
Yeah has happened to Brett and I, I wasnt even driving mine at the time, just lent in the window to knock it into nuetral ... knocked it a bit far and it went into second and wouldnt come out again, we fixed mine with out removing the box but is an absolutle magical act needing mirrors and torches. the selector comes adrift inside the box and it is just a matter of putting it back where it is ment to be, to do this you need to split the box and also remove the top inspection plate, it is prolly a whole lot easier just to pull the box and fix it that way.
Grant
